USG20W-VPN (USG FLEX 50W) configuration migration
Hello!
I have a USG20W-VPN with 5.38(ABAR.0)C0 firmware installed and I would like to know if it is possible to migrate the configuration to any type of USG FLEX100(W)(AX)(H), or any of the current products, without losing any settings.
The goal would be to have higher firewall and VPN throughput, but it would be very helpful if I could migrate the config and would not need to set up everything again.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,611 image  Zyxel Employee
    Hi @mgabor3000,
    There's no configuration migration tool from USG20W-VPN (USG FLEX 50W) to USG FLEX100(W)(AX)(H) currently.
    Zyxel Melen
