[Resolved] SSL_VPN Tunnel not Assigned to Zone/Not generating Hits
SI_Solutions
SI_Solutions Posts: 8 image  Freshman Member
edited July 2024 in USG FLEX H Series
Type: USG FLEX 500H
FW: V.1.20(ABZH.1, 21.05.2024)
I created an SSL-VPN Tunnel, and was able to Set it up using the OpenVPN Client
But upon connecting i lost Internetconnection but was able to connect to the internal services
I noticed, that the Firewall Rules for the SSL_VPN werent generating any Hits.
I created an extra rule to see if i can ge the internet working if i leave the zone empty and use the VPN Subnet as a source, and it worked.
I cannot find where to change the assignment of the SSL-VPN-Tunnel to a zone. and if a check in the Zones there is an Object "ssl-tun" in the Zone, but in the Security Policy the same object is empty.
Anybody else had this experience?
    PeterUK Posts: 4,305 image  Guru Member
    edited May 2024
    Yes seeing the same
    well it was the case but seem to be working for me
  • SI_Solutions
    Strange, your Interface is Called tun0, while mine is called ssl-tun.
    so is mine
  • SI_Solutions
    With the current FIrmware 1.21(ABZH.0) the Object does not correctly show the ssl-tun and also the Firewall Rules now generate Hits.
    This issue has been resolved.
