USG20W-VPN (USG FLEX 50W) configuration migration
mgabor3000
in Security
Hello!
I have a USG20W-VPN with 5.38(ABAR.0)C0 firmware installed and I would like to know if it is possible to migrate the configuration to any type of USG FLEX100(W)(AX)(H), or any of the current products, without losing any settings.
The goal would be to have higher firewall and VPN throughput, but it would be very helpful if I could migrate the config and would not need to set up everything again.
Hi @mgabor3000,
There's no configuration migration tool from USG20W-VPN (USG FLEX 50W) to USG FLEX100(W)(AX)(H) currently.
Zyxel Melen0
Hi @mgabor3000,
Zyxel Melen0 -
Hi @Zyxel_Melen,
Thank you for your answer!0
- 439 Beta Program
- 529 USG FLEX H Series
- 330 Security Ideas
- 49 Wireless Ideas
- 290 Service & License
- 4.6K FAQ
