GS1900-24HP: Disabled PoE on Port Still Powers On at Boot
Greetings!
I have a GS1900-24HP (v2 I believe, just updated to firmware V2.80 ABTP.0). I love this switch! But this is driving me crazy: Port 17 has PoE disabled, still powers up on boot/reboot. Saved the config. When I open the port to edit the settings they are all correct, and when I save from there (see attached image) the PoE powers off. So my question is, is this by design? Do all the ports power-on PoE on boot, no matter what the settings? Seems like a bug. Same issue on the previous firmware. Thx!
Regards,
Dylan
After a thorough review, we've identified that some batches of the GS1900 series PoE switches exhibit the issue you've described. We'll include this bug fix in our later official firmware release.
If anyone encounters a similar issue, please provide your switch's tech support file so we can further investigate.
Kay
Thank you for your inquiry and for sharing your experience with the GS1900-24HP switch. We're glad to hear you love the switch!
Regarding your issue with PoE on Port 17, we have tested similar configurations on firmware versions V2.70(ABTP.5)C0 and V2.80(ABTP.0)C0. In our tests, the configuration remains unchanged after a reboot.
Please ensure that you are saving the configuration correctly after applying the PoE settings. To save the configuration:
- Make the necessary changes to the PoE settings.
- Click the 'Save' button at the top right corner of the switch's local GUI to save the configuration.
If the configuration is not saved properly, it will be erased after rebooting, causing the PoE settings to revert.
If you have followed these steps and are still experiencing the issue, please provide us a video recording and tech support file for us through private msg., and we will further investigate the matter.
Kay
Hi Kay,
As I mentioned, I did save the configuration. The configuration is correct, as shown in the image attached previously.
However, in spite of this, when the switch boots/reboots, there is power enabled on the port, even though the configuration says it is not. I have not tried this on multiple switches, but I have tried multiple at/af power up settings with the same result.
When I go in to edit the port, making no changes but clicking 'Apply,' the PoE powers off immediately. So the impression is, the setting is correct, but the PoE still powers on on boot/reboot.
Regards,
Dylan0 -
Even though you have applied the configuration on the interface, please ensure that you have clicked the 'Save' button at the top right corner of the switch's local GUI to write the configuration permanently to the switch. If you don't click that 'Save' button, the configuration will be erased after rebooting.
If you have already saved the configuration properly and the issue persists, please provide us the following information through private msg. so we can further investigate.
- A video recording of your procedure.
- Switch tech support file
Kay
Kay
- 441 Beta Program
- 210 Nebula Ideas
- 538 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
