Number of people connected to the SSL VPN on an ATP700 ?
Jeanbaptiste
Jeanbaptiste Posts: 7  Freshman Member
edited July 2024 in Security
How can I retrieve the number of people connected to the SSL VPN on an ATP700 firewall via SNMP? I have retrieved the number of system users using the MIB files available on the site, but I cannot find the OID corresponding to the VPN users. Thank you.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317  Zyxel Employee
    Hi @Jeanbaptiste ,
    You can try to use the OID as .1.3.6.1.4.1.890.1.6.22.2.6.1.2 in the "ZYXEL-ZW-COMMON" MIB file to check the related VPN connection name.
    Zyxel_Judy
  • Zyxel_Judy
    edited August 2024
    Hi @Jeanbaptiste ,
    You can use the OID as .1.3.6.1.4.1.890.1.6.22.2.5.1.0 in the "ZYXEL-ZW-COMMON" MIB file to check the related VPN connection info. You can download the ATP700's MIB files at this link
    Zyxel_Judy
  • Jeanbaptiste
    Hi Judy,
    Yes, I have access to this information, but it's the usernames and the number of connections on the SSL VPN that I want to retrieve. I have highlighted the information I am looking for in red.
    Thank you.
  • Zyxel_Judy
    Hi @Jeanbaptiste ,
    Zyxel_Judy
  • Jeanbaptiste
    thank you for your response I solved my problem
    Thank you.
