AD Authentication: Invalid DN syntax
Indeed! It's an unfinished product! You are right!
I hope the missing features will be introduced soon.
I need to manage some APs too… that features will comes in november.
Bye.
Fabio
You know? AD integration will work for the entire directory, not only a selected group or OU.
It's fun! isn't it?
Hi @Fabio_Dangelo,
For the AD to work, the user you use as your login on the Zyxel must be in the Users folder that comes by default from your domain. All other users, it doesn't matter where they are located, you will find them.
Regards
This isn't the problem.
The problem is the password complexity.
A user with simple password works.
Big security problem!0 -
We're experiencing the same issue with our USG FLEX 700H. LDAP Query works fine if we use an Administrator's account, if we put a regular user account for 'Server Authentication', we get the "Invalid DN syntax" error…
- 434 Beta Program
- 174 Nebula Ideas
- 418 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 269 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 87 Security Highlight
