How to use the web CLI window
User196201
User196201 Posts: 1 image  Freshman Member
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Zyxel Employee
    Hi @User196201
    It seems you are asking about the Title bar's CLI window. This window just displays the CLI commands sent by the Web Configurator. These commands appear in a popup window when you click on a menu, such as the Station Info menu. The CLI window is not intended for configuration.
    For more detailed information about the commands, please visit the Zyxel Download Library and refer to the CLI Reference Guide for your specific model.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @User196201
    Zyxel_Judy
    Untitled Image
  • Kepis1981
    Kepis1981 Posts: 1 image  Freshman Member
    edited February 2025
    Thanks for the answer and solving this.
    Summit County Auditors
