Routing LAN1 to WAN1 LAN2 to WAN2
Hi, I have a scenario like this with a USG Flex 100
I have 2 wan WAN1 and OPT_WAN2, WAN2 is currently configured as a backup line in Spillover
In case the primary WAN1 line does not work, WAN2 is activated
Up to this point everything works fine.
The problem arose when I had to route LAN1 to use WAN1 and LAN2 to use OPT_WAN2
I ask for help on where I am going wrong or how to perform this routing function. Thanks
Hi @EMMEGI ,
To classify the scenario, is this you want ?
LAN1 use WAN1 by default, if WAN1 is alive.
If WAN1 has problem, then LAN1 can use WAN2 as backup link.
LAN2 use WAN2 by default, if WAN2 is alive.
If WAN2 has problem, then LAN2 can use WAN1 as backup link.
As the manual says Passive is only used when Active is down
You can do fail over with routing rules
Disable policy route automatically while Interface link down
Enable Connectivity Check0 -
Thanks for your reply and help
But maybe I explained myself badly.
Failover works perfectly. My question was the following
I find myself in front of a scenario with two WANs and two LANs
I would like LAN1 to use WAN1 to navigate and LAN2 to use WAN2
I would like to use WAN2 for customers who come to the company with their notebook which is a backup line that is only needed if WAN1 has problems. But when WAN1 has no problems WAN2 must only serve customers
This is my problem0 -
Hi @EMMEGI ,
Yes, the scenario is more or less what I would like
but currently I would be interested in LAN2 using exclusively WAN2 because it is only a network for passing customers and therefore does not need priority in the event of a service failure. In any case, the scenario proposed above would be perfect0 -
But if WAN 1 is fine the Passive WAN 2 will not work as said this is why you need use routeing fail over
use system default trunk
setup routing rules
rule1
incoming LAN1 next hop WAN1
enable in advanced
Enable Connectivity Check to a IP like DNS 1.1.1.1
rule2
incoming LAN1 next hop WAN2
rule3
incoming LAN2 next hop WAN2
enable in advanced
rule4
incoming LAN2 next hop WAN1
when ping is good LAN1 uses WAN 1 if ping check fail LAN1 uses WAN2
when ping is good LAN2 uses WAN 2 if ping check fail LAN2 uses WAN1
There is no traffic on WAN2. Do you recommend restarting the firewall?
- 415 Beta Program
- 2.4K Nebula
- 152 Nebula Ideas
- 100 Nebula Status and Incidents
- 5.8K Security
- 289 USG FLEX H Series
- 278 Security Ideas
- 1.5K Switch
- 77 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 252 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 75 Security Highlight
