Routing LAN1 to WAN1 LAN2 to WAN2
EMMEGI
EMMEGI Posts: 6  Freshman Member
First Comment Friend Collector Seventh Anniversary
edited August 2024 in Security
Hi, I have a scenario like this with a USG Flex 100
I have 2 wan WAN1 and OPT_WAN2, WAN2 is currently configured as a backup line in Spillover
In case the primary WAN1 line does not work, WAN2 is activated
Up to this point everything works fine.
The problem arose when I had to route LAN1 to use WAN1 and LAN2 to use OPT_WAN2
I ask for help on where I am going wrong or how to perform this routing function. Thanks
  • zyman2008
    zyman2008 Posts: 227  Master Member
    25 Answers First Comment Friend Collector Seventh Anniversary
    Hi @EMMEGI ,
    To classify the scenario, is this you want ?
    LAN1 use WAN1 by default, if WAN1 is alive.
    If WAN1 has problem, then LAN1 can use WAN2 as backup link.
    LAN2 use WAN2 by default, if WAN2 is alive.
    If WAN2 has problem, then LAN2 can use WAN1 as backup link.
    PeterUK Posts: 3,776  Guru Member
    edited August 2024
    As the manual says Passive is only used when Active is down
    You can do fail over with routing rules
    Disable policy route automatically while Interface link down
    Enable Connectivity Check
  • EMMEGI
    Thanks for your reply and help
    But maybe I explained myself badly.
    Failover works perfectly. My question was the following
    I find myself in front of a scenario with two WANs and two LANs
    I would like LAN1 to use WAN1 to navigate and LAN2 to use WAN2
    I would like to use WAN2 for customers who come to the company with their notebook which is a backup line that is only needed if WAN1 has problems. But when WAN1 has no problems WAN2 must only serve customers
    This is my problem
  • zyman2008
    Hi @EMMEGI ,
  • EMMEGI
    This is my problem
  • EMMEGI
    Yes, the scenario is more or less what I would like
    but currently I would be interested in LAN2 using exclusively WAN2 because it is only a network for passing customers and therefore does not need priority in the event of a service failure. In any case, the scenario proposed above would be perfect
    edited August 2024
    But if WAN 1 is fine the Passive WAN 2 will not work as said this is why you need use routeing fail over
    use system default trunk
    setup routing rules
    rule1
    incoming LAN1 next hop WAN1
    enable in advanced
    Enable Connectivity Check to a IP like DNS 1.1.1.1
    rule2
    incoming LAN1 next hop WAN2
    rule3
    incoming LAN2 next hop WAN2
    enable in advanced
    rule4
    incoming LAN2 next hop WAN1
    when ping is good LAN1 uses WAN 1 if ping check fail LAN1 uses WAN2
    when ping is good LAN2 uses WAN 2 if ping check fail LAN2 uses WAN1
  • zyman2008
    edited August 2024
    Hi @EMMEGI ,
    1. Keep the current WAN Trunk setting.
    2. Go to Routing > Policy Route, just add a policy route for LAN2 to WAN2.
  • EMMEGI
    There is no traffic on WAN2. Do you recommend restarting the firewall?
    Schermata 2024-08-02 alle 15.17.47.png Schermata 2024-08-02 alle 15.15.27.png Schermata 2024-08-02 alle 15.15.17.png Schermata 2024-08-02 alle 15.15.07.png Schermata 2024-08-02 alle 15.21.43.png
  • zyman2008
    Hi @EMMEGI ,
    Check the settings of opt-wan2 interface.
    Make sure,
    (1) The type is external
    (2) The ZONE is WAN
    (3) With Gateway setting if the IP address is static.
