Number of people connected to the SSL VPN on an ATP700 ?
How can I retrieve the number of people connected to the SSL VPN on an ATP700 firewall via SNMP? I have retrieved the number of system users using the MIB files available on the site, but I cannot find the OID corresponding to the VPN users. Thank you.
Hi @Jeanbaptiste ,
You can try to use the OID as .1.3.6.1.4.1.890.1.6.22.2.6.1.2 in the "ZYXEL-ZW-COMMON" MIB file to check the related VPN connection name.
Zyxel_Judy
Hi @Jeanbaptiste ,
You can use the OID as .1.3.6.1.4.1.890.1.6.22.2.5.1.0 in the "ZYXEL-ZW-COMMON" MIB file to check the related VPN connection info. You can download the ATP700's MIB files at this link
Zyxel_Judy
Hi Judy,
Yes, I have access to this information, but it's the usernames and the number of connections on the SSL VPN that I want to retrieve. I have highlighted the information I am looking for in red.
Thank you.
Hi @Jeanbaptiste ,
Zyxel_Judy
thank you for your response I solved my problem
Thank you.
- 441 Beta Program
- 209 Nebula Ideas
- 534 USG FLEX H Series
- 338 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
