NWA130BE Web Help No Longer works. Online manual needs updating.
davidfi01
davidfi01 Posts: 26 image  Freshman Member
First Comment First Answer First Anniversary
Webhelp no longer works with latest firmware update.
  • Zyxel_Kay
    Hi @davidfi01
    We have resolved the issue. You can now use the Web Help function on the NWA130BE.
    We apologize for any inconvenience caused.
    Kay
  • Zyxel_Kay
    Hi @davidfi01
    We are aware of this issue and are currently working on it. We will provide updates here as soon as we have any progress.
    In the meantime, you can find the NWA130BE User's Guide here:
    NWA130BE_V6.70_Ed1.pdf (zyxel.com)
    Kay
  • Zyxel_Kay
    Hi @davidfi01
    Kay
  • davidfi01
    Thanks for the update.
