Zyxel NR5101auto reboot
Allan_t
Allan_t Posts: 2 image  Freshman Member
I have a zyxel NR5101 which isn't stable in its LTE connection going from around 1mbps to 120 Mbps, and sometimes just simply loose the internet connection....which I quit disturbing.
It is for our summer house, so 2 questions.
1: is it possible to set it up for auto reboot, because it normally works after that.
2: is it possible for external connection to it.
Any help much appreciated.
  • Bob_C
    Bob_C Posts: 224 image  Master Member
    A schedule reboot feature will be supported in a firmware release, which will be available in September.
    Regards,
    Bob
  • Bob_C
    Regards,
    Bob
