VPN IP from internal LAN range
I need to setup remote access IPSEC for some users, but I need them to get an IP address on the internal LAN range so it routes traffic correctly down a VPN connection. Is this possible?
As PeterUK mentioned, assigning VPN clients an IP address from your internal LAN range is generally not recommended because it can cause routing issues and IP conflicts. Instead, it's best to use a separate, non-overlapping IP range for your VPN clients.
If your goal is to allow VPN clients to communicate with devices on your LAN, you can achieve this by configuring appropriate routing rules. This way, traffic can be correctly routed between the VPN and LAN networks without causing conflicts.
Kay
If device on a LAN have 192.168.1.0/24 with a gateway then VPN IP with 192.168.50.0/24 can route to them devices on the LAN
If the clients connecting by VPN have a LAN of 192.168.1.0/24 or 192.168.50.0/24 you will have problem
Kay
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
