Interface disable longer then lease will then not when re-enable work
PeterUK
PeterUK Posts: 3,892  Guru Member
USG FLEX 200H V1.21(ABWV.0)
P3 config as a WAN set to DHCP connected to DHCP server with a lease for 3 minutes.
When you disable P3 WAN for 5 minutes then re-enable the WAN does not work.
Workaround unplug the Ethernet and back in or change port Negotiate to trigger and DHCP restart.
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,529  Zyxel Employee
    Hi @PeterUK,
    We have addressed this issue and investigating it now. I will update you once I get further information.
    Zyxel Melen
  • Zyxel_Melen
    Hi @PeterUK,
    This issue has been fixed. We will add this fix to the future firmware release.
    Zyxel Melen
    edited August 2024
    So tested the firmware you sent me (thanks) it works but seems to take a long time for the interface to re-enable and start working again.
  • Zyxel_Melen
    Hi @PeterUK,
    Do you mean the period between you enabling the port and the WAN port having traffic to pass through? Could you help to confirm how long it is?
    Zyxel Melen
    edited August 2024
    Yes you disable it for like 5mins then enable then takes a bit of time to get a a IP and start working again not a big problem but you would think it take like 10 seconds
    edited August 2024
    So one test it failed to get a IP over 3 minutes another test shows after enabling WAN takes over 1 minute 30 seconds before it gets a IP and starts working and another test in 60 seconds.
  • Zyxel_Melen
    Hi @PeterUK,
    Thanks for your update.
    We need your help with the investigation:
    1. Collect the diag info after testing and mark the test time. Then we can check the syslog to clarify the process.
    2. It would be helpful if you could collect the DHCP packet at the same time. It can help us to clarify the whole timeline during the process.
    Zyxel Melen
    info sent
