How does the H Series handle ADP?
SAI_Mike
I have an USG FLEX 100 running at a customer location that logs about 35 ADP alerts per day. I installed a 200H at a different customer location and enabled DoS Prevention w/ the default DOS_PREVENTION_PROFILE. The 200H generates no alerts and if I look at Log/Events, the DoS Prevention log is empty. Both of these locations had Juniper Firewalls previously and both logged numerous port scans and floods per day.
Is ADP working on the 200H?
Hi @SAI_Mike,
The DOS prevention feature in H series is the same as ADP. Assuming the traffic or attack pattern is the same, there should be blocked logs. Perhaps you could check if both thresholds are the same to verify whether the criteria are consistent.
- 237 Nebula Ideas
- 6.8K Security
- 747 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
