Configuration files and license in SecuExtender for MacOS
Hi all.
I just wanted to make a backup of my connections configuration and license info for SecuExtender for MacOS.
Where are they stored? If I edit connections I can see name and IP, but no credentials, and "About" says that license is registered with no other infos.
Thank you in advance
Hi @keeno,
Thanks for the information. The configuration and license of your SecuExtender cannot be exported. Also, the license cannot be registered to Windows version SecuExtender since the license you are using is only for MAC. However, you can use the Windows built-in VPN to connect. Therefore, you don't need an additional license.
Zyxel Melen0
Hi @keeno,
Could you share the version of your SecuExtender? It will help us to find the answer to your question.
Zyxel Melen0 -
Hi!
Thank you very much for your reply.
Sure! Here it is: version 1.2.6 (the last one working with macOS Sonoma 14.6.1)
Could you confirm that I don't need any license for Windows version? Since MacOS Sequoia is on the way (I'm a beta tester but I still didn't install it, due to SecuExtender compatibility) I wanted to use a Windows VM in case.
Thank you0 -
Hi @keeno,
Zyxel Melen0
- 441 Beta Program
- 530 USG FLEX H Series
- 332 Security Ideas
- 51 Wireless Ideas
- 294 Service & License
- 461 News and Release
