IKEv2 with PSK not working on Android
Userseb
Userseb Posts: 7 image  Freshman Member
Hi everyone,
I'm trying to set up IKEv2 with PSK on a USG Flex 100 by following that article (https://support.zyxel.eu/hc/en-us/articles/8805317185298-IKEv2-VPN-with-Pre-Shared-key-on-Mobile-Devices-Instead-of-L2TP#h_01HB6CZ468E23YEB63SRPPFRS8) but it's not working.
Here is the log
What could be wrong ? I don't see any error in the log.
Thanks.
Seb
    PeterUK Posts: 4,381 image  Guru Member
    For phase 2 change Local policy to 0.0.0.0
    Is this by IP or DNS?
    Have you tried changing the key group?
    looks like Phase 1 is not done
  • Userseb
    Hi PeterUK,
    It's by IP
    Key groups are DH2 and DH14 as specified in the article (not tried the others)
    Ciphers are AES256/SHA256
    Yes it seems phase 1 do not terminate
    I noticed a [CERTREQ] at line 11 in the log, would it mean that it requests a certificate ? 🤷‍♂️
  • Userseb
    Ok so I'm going to the right direction, phase1 is now OK but phase 2 fails.
    Phase 1 has been solved by changing the IPSec identifier in the client app on Android : I replaced 0.0.0.0 by then WAN IP (192.168.1.99 in my case behing a NAT) and it works.
    Here is the complete log now
    I receive a correct IP (192.168.70.2), the Dynamic Tunnel is built successfully but the microsecond after, IKE SA is disconnected. I tried multiple policies without success. I don't know what else to do.
    Regards,
    Seb
  • Userseb
    Oh man thank you so much it was as simple as that ! 👍👍👍
    Do you know why I had to change this parameter from the subnet to 0.0.0.0 ?
    Seb
    Think it to do with the WAN IP interface is on but by setting it to 0.0.0.0 it can be from any interface
  • Userseb
    Ok I will keep this in mind next time ! Thanks again !
    Regards,
    Seb
