IKEv2 with PSK not working on Android
Hi everyone,
I'm trying to set up IKEv2 with PSK on a USG Flex 100 by following that article (https://support.zyxel.eu/hc/en-us/articles/8805317185298-IKEv2-VPN-with-Pre-Shared-key-on-Mobile-Devices-Instead-of-L2TP#h_01HB6CZ468E23YEB63SRPPFRS8) but it's not working.
Here is the log
What could be wrong ? I don't see any error in the log.
Thanks.
Seb
For phase 2 change Local policy to 0.0.0.0
Is this by IP or DNS?
Have you tried changing the key group?
looks like Phase 1 is not done
Hi PeterUK,
It's by IP
Key groups are DH2 and DH14 as specified in the article (not tried the others)
Ciphers are AES256/SHA256
Yes it seems phase 1 do not terminate
I noticed a [CERTREQ] at line 11 in the log, would it mean that it requests a certificate ? 🤷♂️
Ok so I'm going to the right direction, phase1 is now OK but phase 2 fails.
Phase 1 has been solved by changing the IPSec identifier in the client app on Android : I replaced 0.0.0.0 by then WAN IP (192.168.1.99 in my case behing a NAT) and it works.
Here is the complete log now
I receive a correct IP (192.168.70.2), the Dynamic Tunnel is built successfully but the microsecond after, IKE SA is disconnected. I tried multiple policies without success. I don't know what else to do.
Regards,
Seb
Oh man thank you so much it was as simple as that ! 👍👍👍
Do you know why I had to change this parameter from the subnet to 0.0.0.0 ?
Seb
Think it to do with the WAN IP interface is on but by setting it to 0.0.0.0 it can be from any interface
Ok I will keep this in mind next time ! Thanks again !
Regards,
Seb
On a FLEX 200 5.42(ABUJ.1)
I'm trying to get this working as well for an android/samsung phone.
The difference on my Zyxel VPV gateway is…mine is a static ip.
My phone connects, then disconnects immediately.
What info from the log will help provide some assistance?
Don't want to use strongswan etc, just the default protocols on the Flex 200 and my Samsung phone
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
