New AP with ethernet port for computer etc
nicolascoz
nicolascoz Posts: 2 image  Freshman Member
Good morningI'm looking for a wifi AP that also allows 1-4 ethernet connections, I saw this product, is it correct? ax3000-wifi-6-dual-radio-nebulaflex-pro-wall-plate-access-point-wax300h
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,347 image  Zyxel Employee
    edited August 2024 Answer ✓
    Hi @nicolascoz ,
    You're correct. The WAX300H provides 4 Ethernet connection ports, including 1 uplink port and 3 LAN ports, allowing you to connect up Ethernet devices directly to the access point.
    Additionally, you might want to consider the WAC500H, which offers 3 Ethernet connection ports, including 1 uplink port and 2 LAN ports.
    Both models provide wireless and wired connections, making them suitable for use in hotels or homes. Just a small clarification: The WAX300H functions as an access point, not a router.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @nicolascoz ,
    Zyxel_Judy
    Untitled Image
  • nicolascoz
    merci beaucoup pour votre réponse rapide et claire.
    je vous remercie et vous souhaite une bonne journée.
    cordialement
