Wifi 6E
Hi @AndreasZP
The NWA130BE does not support the BandFlex feature. NWA130BE can broadcast the 2.4GHz+5GHz+6GHz radio in the same time.
BandFlex allows the radio to operate on either the 5 GHz or 6 GHz band, depending on your configuration, which helps fit your 5 GHz coverage while also preparing for future 6 GHz usage. Currently, this feature is only supported on the NWA220AX-6E and the WAX620D-6E.
If you could share the specific configuration you are looking to achieve with the NWA130BE, we’d be happy to help find an alternative solution.
Kay
Hi @AndreasZP
Kay
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
