2FA - two factor authentication | Auto setting Authenticator
Alex_91
Alex_91 Posts: 38 image  Freshman Member
First Comment Friend Collector Seventh Anniversary
Hello, Good morning,
I'm using a firewall with several local users, two-factor authentication has been activated (especially by email) and it works correctly.
I was wondering, is it possible to allow the end user to independently create the authenticator (google auth) without an admin enter in user management to enable it?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    Hi @Alex_91 ,
    Bonus 😊 / second question: (why if I put email address in second textbox I recaive email but no in first?)·
    We will address this issue in the upcoming official firmware release. Please stay updated with the Firewall News & Releases section to know more about the fixes, enhancements, and new features.
    Zyxel_Judy
    Untitled Image
«1
  • Zyxel_Judy
    Hi @Alex_91 ,
    We assume that you want to allow users to create their own accounts and set up two-factor authentication by themselves, and then connect to the network. Please correct me if you have a different idea.
    To better support you, could you please share the following information with us:
    • Which firewall and managed mode (Nebula/On-premise) are you using?
    • Which menu do you use to configure local users?
    • In which scenario/ application users can use after they can independently create the authenticator (Google Auth)?
    Zyxel_Judy
    Untitled Image
  • Alex_91
    Yes correct,
    I answer:
    • Firewall: on-prem (in this first case I would need it for a USG FLEX 200).
      • After is possibile on H Series?
    • admin page login of firewall → Configuration → Object → User → Add User
      • Bonus 😊 / second question: (why if I put email address in second textbox I recaive email but no in first?)
    • Simply allow the various users to connect via VPN but withit 2FA.
      • Would not be a problem to enter in the administration page to create the user with respective email, but then would there be the possibility of creating two-factor authentication regarding the Google Authenticator?
  • Zyxel_Judy
    Hi @Alex_91 ,
    As of now, end users cannot independently set up Google Authenticator without an admin enabling it through user management.
    We have confirmed this issue on our end and are currently investigating it. We will share with you once there are any updates.
    Zyxel_Judy
    Untitled Image
  • Alex_91
    Mmm,
    this feature could be added to ideas for future developments.
  • Zyxel_Judy
    Hi @Alex_91 ,
    Thank you for your feedback.
    You can view and contribute to this idea in the following section: Enabling User-Configured Two-Factor Authentication with Google Authenticator — Zyxel Community
    Thank you for using Zyxel products and services.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @Alex_91 ,
    Zyxel_Judy
    Untitled Image
  • Alex_91
    Will 2FA via email ever be implemented on the H Series too?
  • Zyxel_Judy
    edited September 2024
    Hi @Alex ,
    I'd like to clarify your inquiry. Are you referring to:
    1. The 2FA via email feature for H series devices as general, or
    2. The 2FA via email feature for H series devices, as a feature request for the USG FLEX 200 where end users can independently set up Google Authenticator without an admin enabling it through user management?
    Please specify which option you're asking about, so we can provide you with the most accurate information.
    Zyxel_Judy
    Untitled Image
  • Alex_91
    1. 2FA via email feature for H series devices
  • Zyxel_Judy
    HI @Alex_91 ,
    Currently, we don't have a plan implement this feature (2FA for e-mail) on the USG Flex H model.
    Zyxel_Judy
    Untitled Image
