OpenVPN use client certificate
is it possible to use client certificate with OpenVPN for better security ?
Best regards
Luc
As @PeterUK mentioned, it is currently not supported to import an externally purchased certificate for SSL VPN on the USG FLEX H firewall. The SSL VPN configuration includes default certificates generated by the device, which consist of three components: (1) Server CA, (2) Client CA, and (3) Private Key. These certificates are automatically generated by the device and can be used directly to create an OpenVPN connection.
Kay
Not currently
Kay
- 602 USG FLEX H Series
- 480 News and Release
