XMG1915-10E: Flow Control
Best Answers
Cloud mode.
But even in Nebula interface the options were missing….
10 minutes ago I changed a global configuration for all my switches within Nebula (totally unrelated to flow control) and now I can see "Flow Control" and "Bandwidth Control" options in ports setup page.
But only in Nebula. Accessing the switch configuration page directly doesn't show the options.
Anyway, now my issue is solved ;)
Hi @Matwolf
Once your device is managed in Nebula cloud mode, most settings will be hidden in the local GUI. If you've already registered the device to Nebula cloud mode, please manage it via the Nebula Control Center to access the full configuration options. You can find the Flow Control setting under Site-wide > Configure > Switches > Switch ports.
Kay
Yeah, I've seen that, but unfortunately the column "flow control" is missing in my interface…
odd…I take it this is standalone?
firmware upto date?
Cloud mode.
Ok good to know its in Cloud mode that might be the reason
another way to enable flow-control is by SSH
configure
interface port-channel 8
flow-control on
Hi @Matwolf
Kay
- 429 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 350 USG FLEX H Series
- 291 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.8K FAQ
- 82 Security Highlight
