XMG1915-10E: Flow Control
Matwolf
Matwolf Posts: 7 image  Freshman Member
is it possible to enable Flow Control on this network switch's ports?
On Zyxel website, standard compliance with "IEEE 802.3x flow control" is declared for the entire series of XMG1915 switches.
Best Answers
  • Matwolf
    Cloud mode.
    But even in Nebula interface the options were missing….
    10 minutes ago I changed a global configuration for all my switches within Nebula (totally unrelated to flow control) and now I can see "Flow Control" and "Bandwidth Control" options in ports setup page.
    But only in Nebula. Accessing the switch configuration page directly doesn't show the options.
    Anyway, now my issue is solved ;)
  • Zyxel_Kay
    Hi @Matwolf
    Once your device is managed in Nebula cloud mode, most settings will be hidden in the local GUI. If you've already registered the device to Nebula cloud mode, please manage it via the Nebula Control Center to access the full configuration options. You can find the Flow Control setting under Site-wide > Configure > Switches > Switch ports.
    Kay
  • Matwolf
    Yeah, I've seen that, but unfortunately the column "flow control" is missing in my interface…
    edited August 2024
    odd…I take it this is standalone?
    firmware upto date?
  • Matwolf
    Cloud mode.
    edited August 2024
    Ok good to know its in Cloud mode that might be the reason
    another way to enable flow-control is by SSH
    configure
    interface port-channel 8
    flow-control on
  • Zyxel_Kay
    Hi @Matwolf
    Kay
