OpenVPN, can we combine password+otp in same question ?
My customers use OpenVPN with Flex H and OTP to connect on remote system. It's working fine, but it is tricky to use.
For customer it is very complicate to open web page to send OTP value especially from a mobile device.
Is it possible to add OTP value with password ? like this password + otp value
P.S. We choose OpenVPN because it's working on all system (Windows, Mac, IOS, Android). SecureExtender on Windows can start script after connect to open directly Web page OTP confirmation, but MAC not, and not exist on IOS/Android
Best regards
Luc
Hi @supportIconSA ,
Implementing the scenario, you mentioned depends on your RADIUS server and MFA vendor, not the firewall. While we can't provide a complete FAQ since this isn't directly related to our firewall, we can share some relevant resources for your reference:
Cisco DUO for 2FA — Zyxel Community
Append Mode - Guide to Two-Factor Authentication · Duo Security
These resources should give you a better understanding of how to approach this implementation.
Zyxel_Judy
Hi @supportIconSA ,
Zyxel_Judy
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
