Zywall 110, Trunk, Trouble with WRR
i have Trouble with Funktion after Firmware upgrade. My config ist
WAN1: Unity Media (cable)
WAN 2: VDSL
OPT/WAN3: LTE (off net right now)
So i do an Aktiv/Aktiv WRR over WAN1 and WAN2 for incoming and outgoing traffic. After upgrade vom
4.30 (AAAA.0) to 4.31 or then to 4.32 the LB work not right anymore. With 4.31 it is not possible to get traffic to the WAN2. Not with second App from one PC not with 2nd PC.
With 4.32 Funktion is coming back to get traffic to both WAN IF with different PC.
But i'm missing like on FW4.30 when a multi-session App or Speedtest was able to use BOTH WAN IF at the same time.
Zyxel told me that LB to both WAN-IF is no target of design and there is no faiture if this wont work any more.
Do anybody see similar Prolems or a solution?
Thx, cheers
Sascha
In 4.30 and 4.31 firmware, the routing traffic will transmit by WAN1 or WAN2 interface randomly.
In 4.32 design, If the sessions with the same source IP and destination IP, then routing will keeping on the same WAN interface in a period time.
So as you mentioned on Speedtest, the traffic will keeping on signal WAN but not multi-WAN.
5
5 -
try this speed test as it test with many IP's
Helo,
sorry I opend second Thread, but I explained there more detailed the problem...
https://businessforum.zyxel.com/discussion/2310/zywall-110-trunk-load-sharing
Maybe have a look to understand my problem which already exists in 4.33
@Zyxel_StanleyZyxel_Stanley said:In 4.30 and 4.31 firmware, the routing traffic will transmit by WAN1 or WAN2 interface randomly.
Now it is not possible to use mutli-session apps like ftp etc. over more then one connection.
Thanks for answering
Sascha0 -
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
