USG LITE 60AX - VLAN assignment
ColinSkuse
ColinSkuse Posts: 2 image  Freshman Member
how do i allocate VLANS to port interfaces of the USG LITE 60AX?
  • Zyxel_Kay
    Hi @ColinSkuse
    The USG LITE 60AX does not support direct VLAN assignment to individual port interfaces. However, you can achieve VLAN segmentation in your network by configuring an SSID with a VLAN and allowing devices to connect wirelessly.
    If you need to connect devices via Ethernet, we recommend using a managed switch that supports VLAN configuration. You can explore our range of switches here: https://www.zyxel.com/global/en/products/switch .
    Kay
  • Zyxel_Kay
    Hi @ColinSkuse
    Kay
  • ColinSkuse
    Thanks, post your comment i worked out that all VLANs are allowed on every interface. I am working now with my existing managed switch
