Buying an SCR50 AXE
ZeroCool
ZeroCool Posts: 1 image  Freshman Member
Can the SCR50 AXE also be purchased and used by private persons or is this device reserved for company customers only?
  • Zyxel_Nami
    Zyxel_Nami Posts: 659 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    edited September 2024 Answer ✓
    Hi @ZeroCool
    The SCR 50AXE is available for purchase by both private individuals and businesses. Whether you're a home user or a small and medium office, you can acquire and use this device according to your needs.
    Nami
  • Zyxel_Nami
    Hi @ZeroCool
    Nami
  • GiuseppeR
    GiuseppeR Posts: 664 image  Master Member
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
    Hello @ZeroCool
    you can buy the SCR50AXE and manage it creating a free account on Zyxel platform. It will be a great device to manage also your home network.
