Flex 200H - Sending logs via email
GiuseppeR
GiuseppeR Posts: 550 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
Hello everyone,
in the past I used to send logs via email, like you could do with USG60W.
It was possible for the firewall:
and for the APs managed on premise:
So it was possible to config an email sent for what you wanted to see with the right panel:
Is it possible to do the same also with 200H in the future?
Right now there is no option for that:
Because I can see only syslog and not mailservers.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    Hello Users,
    Currently, the Flex 200H does not support sending logs via email. We've added your request to our feature request list and are evaluating it for future updates.
    To stay informed about new features and enhancements, please follow our Firewall News & Releases.
    Zyxel_Judy
    Untitled Image
    PeterUK Posts: 4,267 image  Guru Member
    Yes I see this as missing so think it be added later
  • GiuseppeR
    edited September 2024
    I agree with you, maybe using directly mail settings that are under System > Notification instead of using another mailserver config
  • Zyxel_Judy
    Hello Users,
    Zyxel_Judy
    Untitled Image
