USG LITE 60AX - VLAN assignment
how do i allocate VLANS to port interfaces of the USG LITE 60AX?
Hi @ColinSkuse
The USG LITE 60AX does not support direct VLAN assignment to individual port interfaces. However, you can achieve VLAN segmentation in your network by configuring an SSID with a VLAN and allowing devices to connect wirelessly.
If you need to connect devices via Ethernet, we recommend using a managed switch that supports VLAN configuration. You can explore our range of switches here: .
Kay
Hi @ColinSkuse
Kay
Thanks, post your comment i worked out that all VLANs are allowed on every interface. I am working now with my existing managed switch
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
