NWA130BE won't go into standalone mode
You really need to fix the NWA130BE.
- It will NOT get an IP through DHCP.
- It will NOT setup as standalone
It's such an unnecessary pain to have to setup a static IP address on my PC and I had to organize a power cable, because I wanted to install the AP using PoE, but that doesn't work for static IPs.
Then, when I finally get to the login page, I'm explicitly asked, if I want to go StandAlone and click on the standalone link. I am asked for a password (*) and to setup time and stuff. OK.
Once rebooted I go to the new IP address, that now can be either a static IP you setup before or it's a random IP depending on DHCP.
Login won't take the password * I created and saved before. Odd, right?
I use the default admin and 1234 and it works. o.O
Then I get this minimalistic interface, where nothing can be set. Where is the standalone setup?
Please do NOT ask me to reset the device using the tiny button. I have done that twice already - with the same result.
Fix your AP.
Hi @FlashBytes
It looks like this device was previously registered to the Nebula Control Center by someone else. If this device is now yours, you can transfer ownership by registering it through the Nebula Mobile App. Please download the Nebula Mobile App from the following links: Android / iOS and scan the QR code sticker on the device to complete the registration.
Once you've registered the device, if you wish to switch it to standalone mode, please follow the guidance provided in the article mentioned above.
For simplified management, we recommend considering Nebula Cloud Mode for managing your APs.
Kay
Hi @FlashBytes
To set up the NWA130BE in standalone mode, please refer to the Quick Start Guide, starting from the section “Option 2 Direct Management.”
If you’re seeing a minimalistic interface with limited settings after logging in, could you please provide a screenshot of what you’re encountering? This will help us better understand the issue.
Additionally, if your device has been registered in Nebula Cloud mode, some configurations on the web GUI may be hidden. Please send us your device’s S/N and MAC address via private message so we can check its status in our backend system.
Thank you for your patience, and we look forward to resolving this for you.
Kay
Hi @FlashBytes
Thank you for sharing your device information via private message.
After reviewing your device status, it appears that your NWA130BE is registered in Nebula Cloud mode, which is why some features are hidden on the web GUI. If you wish to switch your AP to standalone mode, please follow the guidance provided in this article:
Alternatively, if you would like us to handle this for you, please reply to confirm, and we’ll take care of it.
Looking forward to your response!
Kay
Hi @Zyxel_Kay
This is what the web page looks like:
How could my AP be registered in Nebula Cloud mode? Before today I've never logged into the Nebula Cloud.
Plus, while I setup the AP I was never asked to log into any account and when login into the Nebula Cloud I do now with this very same account I have for this forum… there are no devices to be found, which I could remove. Not surprising - for me at least.
Can you see, if this device was previously owned by someone else before I bought it?
Hi @FlashBytes
Kay
Thank you.
Transferring the ownership solved the issue. Now I was able to remove the device from the cloud albeit only through the web portal. The app was not only useless in this regard. It froze and almost crashed my phone.
Hi @FlashBytes
We’d love to hear your feedback to help improve our Nebula Mobile App. Could you please let us know which OS you’re using (Android or iOS) and describe the issues you’ve encountered with the app? Your input is greatly appreciated!
Kay
- 222 Nebula Ideas
- 616 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
