NWA90AX – Local Mode - Remove SSID
reprokaiser
I've created a temporary SSID for a project, which is now obsolete. How can I remove (not hide) the SSID? The firmware is 7.00(2).
Thank you in advance,
Peter
Hi @reprokaiser,
Please click the SSID profile name, WebGUI will pop out a drop-down SSID profile list. You can select the disable to disable this SSID profile or another SSID profile to fulfill your requirement.
Hope it helps.
Zyxel Melen0
Hi @reprokaiser,
Hope it helps.
Zyxel Melen0
- 601 USG FLEX H Series
- 480 News and Release
