Block network access when security policy doesn't comply
Dpj
Dpj Posts: 202 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
Hello everyone,
Question, is it with zyxel possible to auto block network access from network clients when they doesn't comply to our security standards. For example: When an client is infected with ransomware, would it be possible that zyxel detects it, and block all network access of this client?
I know other brands has this option, it would be nice if zyxel has also this kind of options.
I hope to hear from you1.
Yours,
dennis
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    HI @Dpj ,
    Collaborative Detection & Response (CDR) allows you to detect wired and WiFi clients that are sending malicious traffic in your network and then block or quarantine traffic coming from them. In this way, malicious traffic is not spread throughout the network.
    To configure this feature, please go to Configuration > Security Service > Collaborative Detection & Response
    For more information about this feature, please refer to Chapter 39, "Collaborative Detection & Response," on page 880 of the User guide
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    HI @Dpj ,
    Zyxel_Judy
    Untitled Image
  • Dpj
    Great! thx for your answere, we will investigate this option!
    thx.
