Transfer USG1100 config to Flex 500H
MMRHCM
MMRHCM Posts: 4 image  Freshman Member
Need to change firewalls at location. Is this possible? 3rd party utility available? Doesn't appear to be supported via usg configuration converter.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,669 image  Zyxel Employee
    Hi @MMRHCM,
    There's no configuration converter support for USG1100 to USG FLEX 500H(H series).
    Zyxel Melen
  • Zyxel_Melen
    Hi @MMRHCM,
    Zyxel Melen
    PeterUK Posts: 4,448 image  Guru Member
    edited September 2024
    I can see why you would want it to be easy as that I had to go from Zywall 110 to FLEX200H doing lots of rule but was not as bad as I thought had to redesign part of the network due to the way I had done it but was not too bad to change.
    I suggest if the USG1100 has a spare port setup a LAN to a USB Ethernet adapter login with the Flex 500H in place of the USG1100 and start over using the USG1100 as a guide.
