Connectivity Check limitation
USG FLEX 200H V1.21(ABWV.0)ITS-24WK35-0813-240800592
in other models you can have the routeing Connectivity Check ping local interface IP subnet without a gateway and External or Internal but on the FLEX H you can only ping if the interface has a gateway and External.
can this be changed thanks
Hi @PeterUK,
Could you share more details about this problem? Since I can find the "Connectivity Check" in the internal interface configuration page.
Zyxel Melen0
Hi @PeterUK,
Zyxel Melen0 -
I mean by routing rule for the Connectivity Check ping would not work if the next hop was not a External with gateway interface
Ok I rechecked this for Internal on routeing rule and seems to be working now not sure why I tested when not working
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
