Secondary IP addresses on interface problem
PeterUK
PeterUK Posts: 4,826
image  Guru Member
USG FLEX 200H V1.21(ABWV.0)ITS-24WK35-0813-240800592
Howto add secondary IP address on interface? — Zyxel Community
There is no primary so I have
/ vrf "main" interface ethernet "ge4" ipv4 address "192.168.255.235/26"
/ vrf "main" interface ethernet "ge4" ipv4 address "192.168.255.253/26"
/ vrf "main" interface ethernet "ge4" ipv4 address "192.168.255.248/26"
With a VPN for interface Ge4 to nailed up to 192.168.255.243 my USG40 only that end is expecting from 192.168.255.235 which I think was the primary only the FLEX200H randomly picks how it sends VPN connection out from and so the VPN fails not much I can do so I had the other end nailed up to 192.168.255.235 to make it work for now.
So there need to be a primary.
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,242
    image  Zyxel Employee
    Hi @PeterUK,
    From your screenshot, the My Address part is still using the interface rather than fixing the virtual interface IP address. Please reference the below.
    Zyxel Melen
  • Zyxel_Melen
    Hi @PeterUK,
    Since the virtual interface cannot set orders now, could you help to change the VPN setting > Network > My address from the interface to a fixed IP address? This should avoid randomly picking the IP address.
    Zyxel Melen
    image  Guru Member
    edited September 2024
    It is fixed
    The problem is when nailed up on FLEX200H side the source IP of ge4 LAN can pick from
    The other end is expecting say 192.168.255.235 but the FLEX200H uses 192.168.255.248 as source when nailedup and so their is a mismatch.
  • Zyxel_Melen
    Hi @PeterUK,
    Zyxel Melen
    image  Guru Member
    Hi Melen
    I over looked that option so that works
    thanks
