Connectivity Check limitation
PeterUK
USG FLEX 200H V1.21(ABWV.0)ITS-24WK35-0813-240800592
in other models you can have the routeing Connectivity Check ping local interface IP subnet without a gateway and External or Internal but on the FLEX H you can only ping if the interface has a gateway and External.
can this be changed thanks
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @PeterUK,
    Could you share more details about this problem? Since I can find the "Connectivity Check" in the internal interface configuration page.
    Zyxel Melen
  • Zyxel_Melen
    Hi @PeterUK,
    Zyxel Melen
    edited September 2024
    I mean by routing rule for the Connectivity Check ping would not work if the next hop was not a External with gateway interface
    Ok I rechecked this for Internal on routeing rule and seems to be working now not sure why I tested when not working
