Transfer USG1100 config to Flex 500H
Hi @MMRHCM,
There's no configuration converter support for USG1100 to USG FLEX 500H(H series).
Zyxel Melen0
Hi @MMRHCM,
Zyxel Melen0 -
I can see why you would want it to be easy as that I had to go from Zywall 110 to FLEX200H doing lots of rule but was not as bad as I thought had to redesign part of the network due to the way I had done it but was not too bad to change.
I suggest if the USG1100 has a spare port setup a LAN to a USB Ethernet adapter login with the Flex 500H in place of the USG1100 and start over using the USG1100 as a guide.
- 435 Beta Program
- 176 Nebula Ideas
- 426 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
