pfSennse,switch replacement from tplink to Zyxel,VLans not working
I am the one that installed the Switch and configure it, they did nothing on the switch…
Can we check anything else,does this switch have a CLI or something?
Be interesting to see if all works with the TP switch again
unless you got port 10 and 12 mixed up
Hi @ArmoredPCs,
Thanks for the MAC table. Thanks for the MAC table. I apologize for replying late I was doing a lab in my office.
From your MAC table, I noticed the GS1900 only learns your pfSense on VLAN1 but no other VLANs like VLAN200. In my lab, my GS1900 learns my pfSense not only VLAN1 but also 20 and 100. My Client connects to port 18 which is in VLAN100.
And my PC gets IP from VLAN100.
Also, there is traffic on VLAN100.
Could you help to check your pfSense setting and its NIC card setting, like VLAN and priority? Your issue is more likely on pfSense. The switch configuration should be good.
Zyxel Melen0 -
Hello,sorry for the late reply
I did happen to find the fix for the issue and works exacly as i wanted it.
Somehow when i uninstalled Suricata (IDS-IPS) it started to give the correct IPs - subnets and VLANS to the devices.
Suricata was configured to work only for VLAN1 (Internal)
I have really no idea why would this happen with zyxel switch and no with the tp-link one, what difference it makes on how they communicate.
I haven't add vlan priority as you asked, What NIC settings would you require me to check?
Could it be NIC and Switch ports compatibility?
Hi @ArmoredPCs,
Thanks for updating the result with us~
The VLAN priority is the configuration of my NIC card. In your case, it is more likely related to "Suricata". So, you don't need to change this configuration on your side.
Zyxel Melen0
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
