web sites issues
Hi there, I've changed my old usg40 with an atp200, using very basic rules.
Since I've swapped my firewall, I'm unable to access wordpress editor on some sites.
It's a great issue, since we work on creating sites.
Do anyone know what could has been changed?
Thanks in advance.
Thanks in advance.
@Eggers_it
Regarding this case,
can you disable firewall and see the site can be accessed or not?
If after disabled, the site can be accessed, you should check UTM profile for each rule which may block session to wordpress site.
Charlie1 -
@Zyxel_Charliethank you for your answer.
While my Zywall is disabled, the three sites I'm having issues with are all accessible.
I'll try to check the UTM profile, as You suggested. Thank you.0
- 234 Nebula Ideas
- 6.7K Security
- 706 USG FLEX H Series
- 369 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 313 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
