Geo IP filter works too much
SandB
SandB Posts: 22 image  Freshman Member
First Comment Seventh Anniversary
I'd like to block traffic from China and I set Geo IP filter.
Traffic from China is blocked. But part of traffic from Japan is also blocked.
I must receive traffic from Japan.
What can I do?
  • SandB
    Thank you for your comment.
    My device is USG110.
    Auto Update of Geo IP screen was not checked. That's maybe my mistake.
    After update, Geo IP is working well.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,316 image  Zyxel Employee
    Hi @SandB ,
    To better support you, could you share with us:
    • The model's name and firmware version
    • Which Japan IP/ traffics are blocked
    • The Geo IP filter configuration screen
    • The configuration file (Startup-config file at Maintenance > File Manager > Configuration File)
    Zyxel_Judy
    Untitled Image
  • SandB
