Flex 700 to Flex 700H migration
Delta69
Delta69 Posts: 6 image  Freshman Member
I'd like to replace an existing Flex 700 firewall with the newest Flex 700H.
I didn't see any way to convert the current configuration file with the online converter tool.
Can I upload directly the config file from the old system to the new one or is there a way to do so ?
Thanks !
    PeterUK Posts: 4,426 image  Guru Member
    edited March 2024
    The config layout is not the same it can't be converted
    Seems odd you would need to move from a FLEX 700? is it the speed you need?
  • Delta69
    The 1Gbps-only network ports and the CPU usage limitations I encounter encourage me to replace my existing Flex 700. I was wondering if the migration was made easier by staying with the same brand (like I did when upgrading from USG310 to my current model thanks to the online config converter).
  • Delta69
    So… the only way is to restart the configuration from scratch ? :-(
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    @Delta69 we're deploying a configuration converter for USGFLEX migrating to USGFLEX H series.
    The expected schedule would be at the half of this year.
  • Delta69
    Hi James,
    Any news about the availability of the config converter ?
    Regards
  • dkyeager
    dkyeager Posts: 71 image  Ally Member
    Make certain to check the 700H release notes for 700 features not yet available in the 700H. Otherwise you could be severely disappointed.
  • Delta69
    Hi Dkyeager,
    Thanks for the tip, I'll check it more in deep. Which major differences do you have in mind ?
    Regards
  • pcaioo
    pcaioo Posts: 1 image  Freshman Member
    Any Trial or Beta Version?
  • Delta69
    I'm still interested in the answer to this question! Thanks!
