Try Nebula AI Search for a Chance to Win a Nebula Pro Pack License
I don't have a firewall to test this.
Hi @jpblanch75
The Intent feature helps guide you to the appropriate configuration settings based on the questions you ask. You can try it with any device. The users above happened to explore some Firewall-related configurations. :)
Nami
saw the question
from the nebula section and tried it with this intent. i think it 's quite good to tell me to check the wifi aid and health with this type of question.
Here are my results.
Regards…
Hi Everyone,
First, a huge thank you to all of you for joining and making this activity a success!
The moment has arrived – we’ve started sending out the NCC Pro Pack 1-month license keys to all of our qualified participants: @GiuseppeR @gordonre @Caroll @monkeynia @ConAle
Be sure to check your inbox! You should see an email like this – don’t miss out!
Stay tuned to our community announcements for updates on the next activity!
Thank you.
Nami
2 -
Hi @GiuseppeR
The campaign has concluded, and we greatly appreciate your feedback on the Intent feature. Below is our response:
I think that Intent is too excited to work with 200H firewalls that it does not match them:
⇒ The NCC Intent is currently not displaying hyperlinks because the device is set to monitor mode.
Please tell Intent that "Security Router" like LITE60 has the possibility to have also Remote Access VPN:
⇒ For the LITE60 Security Router you can configure Remote Access VPN by scrolling down the bar to find it, as below screenshot.
Nami
Hello @gordonre
Regarding your findings on Security Router and Firewall, the Intent shows a hyperlink on the path depending on the device type (Firewall, Security Router, or Security Gateway). If it doesn't match, the hyperlink won't appear.
We appreciate your suggestion on the name and have forwarded it to our internal team for further evaluation.
Nami
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
