200H IPSec VPN remote access authorization failure
bbp
bbp Posts: 70 image  Ally Member
First Answer First Comment Friend Collector Sixth Anniversary
edited September 2024 in USG FLEX H Series
200H firmware V1.21(ABWV.0)ITS-24WK37-0909-240801054
On 1.21 series firmware I'm getting IPSecVPN authorization failure. It worked on 1.20 with same settings.
From 200H logs:
generating INFORMATIONAL response 2 [ N(AUTH_FAILED) ]
parsed INFORMATIONAL request 2 [ N(AUTH_FAILED) ]
generating IKE_AUTH response 1 [ IDr CERT AUTH EAP/REQ/ID ]
parsed IKE_AUTH request 1 [ IDi N(INIT_CONTACT) CERTREQ IDr CPRQ(ADDR ADDR6 DNS DNS6) SA TSi TSr N(MOBIKE_SUP) N(NO_ADD_ADDR) N(MULT_AUTH) N(EAP_ONLY) N(MSG_ID_SYN_SUP) ]
generating IKE_SA_INIT response 0 [ SA KE No N(NATD_S_IP) N(NATD_D_IP) CERTREQ N(FRAG_SUP) N(HASH_ALG) N(CHDLESS_SUP) N(MULT_AUTH) V V ]
selected proposal: IKE:AES_CBC_256/HMAC_SHA2_512_256/PRF_HMAC_SHA2_512/MODP_3072
configured proposals: IKE:AES_CBC_256/HMAC_SHA2_512_256/PRF_HMAC_SHA2_512/MODP_3072
received proposals: IKE:AES_CBC_256/HMAC_SHA2_512_256/PRF_HMAC_SHA2_512/MODP_3072
xxx.xxx.xxx.xxx is initiating an IKE_SA xxx.xxx.xxx.xxx 500 xxx.xxx.xxx.xxx
parsed IKE_SA_INIT request 0 [ SA KE No N(NATD_S_IP) N(NATD_D_IP) N(FRAG_SUP) N(HASH_ALG) N(REDIR_SUP) ]
strongSwan Android client logs:
Starting IKE service (strongSwan 5.9.14, Android 14 Linux 5.10.198-android12-9-o-g9879b9c8974a, aarch64, org.strongswan.android)
providers loaded by OpenSSL: default legacy
loaded plugins: androidbridge charon android-log socket-default openssl nonce pkcs1 pem x509 xcbc kdf revocation eap-identity eap-mschapv2 eap-md5 eap-gtc eap-tls
spawning 16 worker threads
all OCSP validation disabled
all CRL validation disabled
initiating IKE_SA android[4] to xxx.xxx.xxx.xxx
generating IKE_SA_INIT request 0 [ SA KE No N(NATD_S_IP) N(NATD_D_IP) N(FRAG_SUP) N(HASH_ALG) N(REDIR_SUP) ]
sending packet: from xxx.xxx.xxx.xxx[45546] to xxx.xxx.xxx.xxx[500] (592 bytes)
received packet: from xxx.xxx.xxx.xxx[500] to xxx.xxx.xxx.xxx[45546] (665 bytes)
parsed IKE_SA_INIT response 0 [ SA KE No N(NATD_S_IP) N(NATD_D_IP) CERTREQ N(FRAG_SUP) N(HASH_ALG) N(CHDLESS_SUP) N(MULT_AUTH) V V ]
received strongSwan vendor ID
received unknown vendor ID: 8a:3b:5b:d4:b8:94:b2:f3:37:0c:1e:65:67:2e:ec:44
local host is behind NAT, sending keep alives
received cert request for "CN=USG_FLEX_200H_FC22F4BE3C31"
sending cert request for "CN=USG_FLEX_200H_FC22F4BE3C31"
establishing CHILD_SA android{4}
generating IKE_AUTH request 1 [ IDi N(INIT_CONTACT) CERTREQ IDr CPRQ(ADDR ADDR6 DNS DNS6) SA TSi TSr N(MOBIKE_SUP) N(NO_ADD_ADDR) N(MULT_AUTH) N(EAP_ONLY) N(MSG_ID_SYN_SUP) ]
sending packet: from xxx.xxx.xxx.xxx[38888] to xxx.xxx.xxx.xxx[4500] (384 bytes)
received packet: from xxx.xxx.xxx.xxx[4500] to xxx.xxx.xxx.xxx[38888] (1232 bytes)
parsed IKE_AUTH response 1 [ IDr CERT AUTH EAP/REQ/ID ]
received end entity cert "CN=USG_FLEX_200H_FC22F4BE3C31"
no trusted RSA public key found for 'xxx.xxx.xxx.xxx'
generating INFORMATIONAL request 2 [ N(AUTH_FAILED) ]
sending packet: from xxx.xxx.xxx.xxx[38888] to xxx.xxx.xxx.xxx[4500] (96 bytes)
  • bbp
    It seems if "Certificate for VPN Validation" is set to "Auto" it gets confused if there are more than few generated certificates.
    Manually selecting certificate solves that issue.
  • bbp
  • Dylan96
    Dylan96 Posts: 35 image  Freshman Member
    Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
    Thank you @bbp !
    I had the same problem with a 500H after upgrading to V1.32 (ABZH.0) firmware.
    Despite only having one certificate, changing from automatic to manual resolved the issue…
