VPN Down
RaphaelOIiveria
Hi.
My VPN is down after enable NAILED-UP option.
A disable this option but my VPN not connect.
@RaphaelOliveira
The VPN behavior is that after you modify the setting, the session will be disconnected.
However, if you enabled Nailed-UP option, the VPN will disconnect and reconnect immediately.(If you see the icon display disconnect, just refresh web page)Charlie
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
