2 or 3 in Standalone Mode provides all features?
Best Answers
Hi @Peter5_,
Please reference our website product information to find the access point model's support features.
Roaming and mesh, in the standalone mode we call it "WDS", are supported for our access points. Below are some FAQs for you to reference.
Establishing a Reliable WDS Connection on Standalone APs — Zyxel Community
The Difference Between Roaming and Mesh in Wireless Networks — Zyxel Community
Zyxel Melen1 -
Hi @Peter5_,
I have all 3-4 APs connected with wired Ethernet. So there shouldnt be any problems?
There will be no problems with the wired connection.
And why is internet needed?
If your network is an intranet and there's no traffic from/to the Internet, then the Internet isn't needed. In addition, since our access point enables NCC discovery by default, you will find the access points try to connect to the Internet. You can disable NCC discovery to fulfill your requirement.
Zyxel Melen0
Hi @Peter5_,
Zyxel Melen1 -
I have all 3-4 APs connected with wired Ethernet. So there shouldnt be any problems? And why is internet needed?
Hi @Peter5_,
Zyxel Melen0
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
