configure sfp port
mnsandler
mnsandler Posts: 5  Freshman Member
  • Zyxel_Kay
    Zyxel_Kay Posts: 1,279  Zyxel Employee
    Hi @mnsandler
    To better assist you, could you please provide more details about your issue? Specifically:
    1. What model of firewall are you using?
    2. What device are you trying to connect to the firewall?
    3. Could you share your network topology with us?
    4. What configuration and setup are you aiming to achieve?
    Kay
  • mnsandler
    1. flex 200
    2. XZSNET 1000BASE-T SFP Transceiver (https://a.co/d/7kgaYWs)
    3. dual wan, 1 lan
    4. i want to add lan3 via the sfp port using the transceiver in #2
  • mnsandler
    you can close this thread. i have an open support ticket to assist me.
  • Zyxel_Kay
    Hi @mnsandler
    Thank you for providing additional information.
    Could you also share your support ticket number with us?
    Kay
