Create a firewall rule based on a port forwarding rule
Aleksey_Kh
Aleksey_Kh Posts: 3 image  Freshman Member
It would be very convenient if it were possible to create a firewall rule automatically based on forwarding!
I find this part of the settings very inconveniently implemented now
Other vendors make forwarding much easier, but here you can't even copy a rule\policy as far as I can see. And if you need to open a lot of ports, you'll have to configure it all for quite a long time
3 votes
Active · Last Updated
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,651 image  Zyxel Employee
    Hi @Aleksey_Kh,
    Could you share the vendors' name for us to survey? Thanks.
    Zyxel Melen
  • Aleksey_Kh
    Example - Mikrotik, DrayTek, Keenetic, there you only need to create a port forwarding rule.
    Fortigate - there is also no need to create a separate firewall permission rule for port forwarding
  • Zyxel_Melen
    Hi @Aleksey_Kh
    Thanks for sharing this idea. We will monitor the comments and the votes of this idea post to evaluate it.
    Zyxel Melen
