Ping timeout problem
USG FLEX 200H V1.21(ABWV.0)ITS-24WK35-0813-240800592
So after moving to the FLEX200H there are some problems I'm seeing not sure I can simplify this one it part of the fail over system now with Flex200H instead of Zywall 110.
https://community.zyxel.com/en/discussion/comment/51334/#Comment_51334
/ vrf "main" interface vlan "VLAN443" ipv4 address "192.168.44.1/28"
/ vrf "main" interface vlan "VLAN443" ipv4 address "192.168.44.4/28"
There are three ping rules to 192.168.44.4 to the Flex200H from VPN300
So when its working for one of these rules ping from 192.168.44.5 from VPN300 to 192.168.44.4 of FLEX200H which then does NAT of the ICMP to 192.168.254.33 and routing rule to SNAT from 192.168.44.1 static route 192.168.254.32/29 to 192.168.44.5 which the VPN300 sends down the tunnel to my FLEX200 for a reply which then replies back to FLEX200H and then reply back to VPN300.
With FLEX200H timeout for ICMP set to 5 seconds I I'm getting a lot of time outs where by the VPN300 would send a ping to 192.168.44.4 and FLEX200H would not do its thing but as a workaround if I set timeout for ICMP set to 1 second the problem mostly goes away.
My guess is due to the way ping is indirectly getting a reply that the FLEX200H still waits 5 seconds so when another ping happens to 192.168.44.4 its dropped.
Hi @PeterUK ,
Thank you for providing detailed information about the topology and testing steps via private message.
We were able to reproduce the issue and have identified a solution. This fix will be included in the next official firmware version, 1.30.
Zyxel_Judy
PM sent to Judy to look at
What I get From VPN300 when FLEX200H timeout for ICMP set to 5 seconds
2024-09-16 11:35:42
notice
Connectivity Check
Policy Route 37 status is set to ACTIVE by connectivity-check
7
2024-09-16 11:35:41
notice
Connectivity Check
Policy Route 37 status is set to INACTIVE by connectivity-check
8
2024-09-16 11:35:41
alert
Connectivity Check
The link status of policy 37 is inactive.
9
2024-09-16 11:35:40
notice
Connectivity Check
Policy Route 36 status is set to ACTIVE by connectivity-check
10
2024-09-16 11:35:40
notice
Connectivity Check
Policy Route 35 status is set to ACTIVE by connectivity-check
12
2024-09-16 11:35:39
notice
Connectivity Check
Policy Route 36 status is set to INACTIVE by connectivity-check
14
2024-09-16 11:35:38
alert
Connectivity Check
The link status of policy 36 is inactive.
15
2024-09-16 11:35:38
notice
Connectivity Check
Policy Route 35 status is set to INACTIVE by connectivity-check
16
2024-09-16 11:35:38
alert
Connectivity Check
The link status of policy 35 is inactive.
20
2024-09-16 11:35:27
notice
Connectivity Check
22
2024-09-16 11:35:26
notice
Connectivity Check
23
2024-09-16 11:35:26
alert
Connectivity Check
32
2024-09-16 11:35:09
notice
Connectivity Check
34
2024-09-16 11:35:08
notice
Connectivity Check
35
2024-09-16 11:35:08
alert
Connectivity Check
36
2024-09-16 11:35:06
notice
Connectivity Check
38
2024-09-16 11:35:05
notice
Connectivity Check
39
2024-09-16 11:35:05
alert
Connectivity Check
40
2024-09-16 11:35:00
notice
Connectivity Check
42
2024-09-16 11:34:59
notice
Connectivity Check
43
2024-09-16 11:34:59
alert
Connectivity Check
44
2024-09-16 11:34:56
notice
Connectivity Check
46
2024-09-16 11:34:56
notice
Connectivity Check
47
2024-09-16 11:34:56
alert
Connectivity Check
48
2024-09-16 11:34:54
notice
Connectivity Check
50
2024-09-16 11:34:53
notice
Connectivity Check
51
2024-09-16 11:34:53
alert
Connectivity Check
The link status of policy 35 is inactive.0 -
Hi @PeterUK,
We have a few points to discuss with you. Please check your private message.
Zyxel_Judy
Maybe I should start from the beginning as to the problem I need to solve
So I have a PC with LAN IP 192.168.255.55 with DNS 192.168.255.60 (which NAT to 192.168.255.62) which I only want to work when the VPN tunnel is drop when tunnel is up I have a routeing rule #35 that goes nowhere and the idea is when routing rule ping check fails the next routeing rule #39 becomes active and DNS for 192.168.255.55 works to 192.168.255.60 NAT to 192.168.255.62
As their is no way directly to send a routing rule ping down the tunnel on VPN300 I had to do it the way I said by having the routing rule do nothing to ping 192.168.44.4 which pings back 192.168.254.33 to go down the tunnel and comes out FLEX200 sending the reply to FLEX200H which is setup the way Zywall 110 was setup.
the problem just has to do with this ICMP timeout which works better at 1 then 5
Hi @PeterUK ,
Zyxel_Judy
Looks to be fixed in V1.30 👍️
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
- 106 Security Highlight
