SecuExtender is not supported on MacOS 15 (Sequoia)
Best Answers
Hello @RSaull
Currently, we don't have plans to support Mac OS 15 for the SecuExtender VPN client. When Mac OS 15 is released, you may consider using the native VPN client as a workaround solution.
Share your feedback through our survey, make your voice heard, and win a WiFi 7 AP! https://bit.ly/2024_Survey_Community
2 -
Hi @RSaull
The current SecuExtender VPN client is version 1.2.6, and its last supported Mac OS should be Mac OS 14 Sonoma. Its EOL date is 2024-09-01. Please refer to this link. Thanks.
@Zyxel_Jeff I apologize. I didn't realize that MacOS Sequoia was in preview when the user reported the issue to me. If there are any preview builds of SecuExtender that work with Sequoia available, please let me know!
OK, noted it. Thanks.
Hello @RSaull
2 -
Any update on this please?- mac os sequoia 15.0 For Zyxel- USG210- Zywall SSecuExtender?
Any update please??
Hello
what will be the native macOS configuration to replace SecuExtender ?0 -
Y’ll be better off ditching the Zyxel firewall straight away and move over to SonicWall because they don’t have these kind off update issues on supporting MacOS Sequoia. We have two customers that cannot upgrade macOS because Zyxel are still in the dark about Mac updates. Super customer support Zyxel. Native VPN sucks and is not so safe to use. Why does this take so long, October again? Every year it’s the same old story. It’s not like the beta test came out yesterday…. I’m not a very happy customer.
I was remembering last year, when I was stuck for 2 months without VPN because of the update. This year I decided not to make the update, but my mac decided for me 😭.
So the same as last year ; stuck without VPN, and now Zyxel don't even plan to make an update.
Worse thing, the client just say "I am not compatible" ; may be it could work, if they just remove the OS Version check.
- 415 Beta Program
- 2.4K Nebula
- 143 Nebula Ideas
- 94 Nebula Status and Incidents
- 5.6K Security
- 236 USG FLEX H Series
- 267 Security Ideas
- 1.4K Switch
- 71 Switch Ideas
- 1K Wireless
- 40 Wireless Ideas
- 6.3K Consumer Product
- 246 Service & License
- 383 News and Release
- 82 Security Advisories
- 29 Education Center
- 3.2K FAQ
- 71 Security Highlight
